Date/Time: Thu, 16 May 2024 07:11:59 +0000
[User Discussion] - Is it possible to run Sierrachart on MS Surface pro
View Count: 1382
[2016-07-06 16:53:06] |
User449811 - Posts: 8 |
Did anyone manage to install SC on Surface pro 4?
[2016-07-06 17:36:15] |
We are going to mark this as a user discussion. Have you tried running it on your MS surface Pro?
[2016-07-07 06:29:09] |
User13668 - Posts: 291 |
I would say 'yes', as I have had it running just fine on one of these: http://linxtablets.com/ the Linx1010 SC works just fine on it. |
