Date/Time: Sat, 04 May 2024 14:19:30 +0000
s_SCTradeOrder
View Count: 1674
[2013-07-16 11:37:42] |
User40073 - Posts: 23 |
Hello, How can I get s_SCTradeOrder::EntryDateTime, ::LastActivityTime in milliseconds? thanks |
[2013-07-17 09:48:52] |
This is supported. You just need to assign s_SCTradeOrder::EntryDateTime or LastActivityTime to a SCDateTimeMS type. Example: //When working with milliseconds it is necessary to define variables of type SCDateTimeMS SCDateTimeMS DateTimeMS; // Get the milliseconds for the current bar. Usually this will be 0. This is only an example of how to do it. DateTimeMS = sc.BaseDateTimeIn[sc.Index]; int MilliSecond = DateTimeMS.GetMilliSecond(); Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-07-17 09:49:23] |
Although actually thinking about it, the milliseconds for these will always be 0.
