Date/Time: Thu, 16 May 2024 06:19:21 +0000
Flattern doest not acceptet because risk management in Rithmic
View Count: 1026
[2016-07-05 15:11:06] |
User36865 - Posts: 10 |
Hi, for your information, I have issue with Rithmic. When Im short 3 contracts (max in TST Combine) and use Flattern button in my platform, position not be flattern. This is error from log: Rithmic Trading | Failure with order with Service Order ID: 50719575. Rejected at RMS - Total buy quantity of contract would exceed its limit | 2016-07-05 10:01:33 * Rithmic Trading order update (Order update). Info: Rejected at RMS - Total buy quantity of contract would exceed its limit. Internal Order ID: 2869. Service Order ID: 50719575. Symbol: CLQ6-NYMEX | 2016-07-05 10:01:33 * This is bug or attribute ? Thank you. |
[2016-07-05 17:17:02] |
Most likely this explanation here explains this: https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#RejectedMarketOrderWhenUsingFlatten We will be developing a solution to this but we do not know how soon it will be available. The solution does have some risk itself because it will delay the transmission of the market order until the other orders are canceled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
