Date/Time: Wed, 15 May 2024 10:05:40 +0000
SGX (Singapore exchange) futures symbols
View Count: 948
[2016-07-05 13:37:55] |
User282572 - Posts: 6 |
Hello, Can you add EN which is S&P CNX nifty index? also MNF which is E-micro of the same index. I am using CQG datafeed. Thanks |
[2016-07-05 17:44:34] |
Yes we can add these. This will be done after the close today.
[2016-07-06 05:53:34] |
These have both been added. You will see them now listed in File >> Find Symbol >> Futures. Let us know if they work properly for you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-06 09:59:46] |
S&P CNX nifty index is working. MNF didn't bring any data...maybe not trading. I am happy with CNX nifty. Thank you |
