Date/Time: Thu, 16 May 2024 02:23:49 +0000
[Programming Help] - Renko alert on trend change
View Count: 1736
[2016-07-05 09:50:52] |
User457299 - Posts: 38 |
Is it possible to have an alert whenever Renko chart change colour or trend? I have tried the following formula =OR(ID0.SG21>ID0.SG22,ID0.SG21<ID0.SG22) but to no avail. Can anyone help on that? Thanks. |
[2016-07-05 12:04:00] |
Sawtooth - Posts: 3997 |
Try this: =OR(AND(ID0.SG22[-1]>ID0.SG23[-1],ID0.SG22<ID0.SG23),AND(ID0.SG22[-1]<ID0.SG23[-1],ID0.SG22>ID0.SG23)) Here's the documentation: http://www.sierrachart.com/index.php?page=doc/doc_StudyChartAlertsAndScanning.php#BaseGraphIdentifiers |
[2016-07-05 13:00:53] |
I have tried but don't work. I even add colour bar based on alert but shows nothing. I have check the documentation you sent me, it should be able to have an alert. Is there other formula for the Renko alert. |
[2016-07-05 14:02:29] |
The formula works on the Renko bar period type in Chart Settings. This is the recommended method for Renko. Are you using the Renko Chart study instead? |
[2016-07-05 14:08:47] |
Yes. I am using Renko chart. http://www.sierrachart.com/image.php?Image=1467727631572.png |
[2016-07-05 14:38:42] |
Try this: =OR(AND(ID3.SG1[-1]>ID3.SG4[-1],ID3.SG1<ID3.SG4),AND(ID3.SG1[-1]<ID3.SG4[-1],ID3.SG1>ID3.SG4)) where ID3 is the Renko Chart study. Edit as needed for your situation. The same documentation applies: http://www.sierrachart.com/index.php?page=doc/doc_StudyChartAlertsAndScanning.php |
[2016-07-05 15:03:23] |
Thanks a lot. I finally got it. Really appreciated that. Thanks again. |
