Date/Time: Mon, 06 May 2024 22:45:59 +0000
Chart Trading
View Count: 1382
[2013-07-16 09:18:11] |
User96105 - Posts: 113 |
I like to have standings orders in place which may be well away from the current price action. It would be useful therefore to create an order type which flattens the existing position/s(if any) and then sells/buys at the defined price. How can this be done? How do I create a new order which is a child of an existing order? (or even a child of an existing child?) Thanks, Tony |
[2013-07-16 18:46:22] |
You just need to submit an order with the appropriate order quantity which will flatten your position and establish a new position in the quantity that you want. Set that order to the price that you want. This is all. We would think this would be very obvious. In regards to the 2nd question, it sounds as though you are looking to Send Attached Orders. Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_OrderTypes.html#SendAttachedOrders Child orders on child orders are not supported. This gets to be too complicated. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-16 18:48:10
