Date/Time: Sat, 07 Nov 2026 10:47:59 +0000
Amp/Cqg Bid Ask volume
View Count: 1432
| [2016-07-05 08:59:08] |
| User840210 - Posts: 2 |
Is the Bid Ask volume data from Amp/CQG accurate? How much historical Bid/Ask volume data do they provide? Many Thanks |
| [2016-07-05 10:29:24] |
Yes, the bid volume and ask volume is accurate when using CQG. The amount of historical data depends upon the symbol. Tell us one of the symbols you want to chart and trade. You will also need Sierra Chart service package 5 for historical tick by tick data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
