Date/Time: Fri, 10 May 2024 18:04:17 +0000
Activity Log issues
View Count: 694
[2016-07-02 17:09:26] |
MoneyMavin749 - Posts: 2 |
My activity log does not post any of my trades. Trade simulation mode on is unchecked and it does show the times I entered and exited the trade but that's it. For everything else ie. order status and trade account it says "unspecified" and "None". When I click on show order fills on chart they appear on the chart as well as when I click on Trade orders and positions. It is just when I try and use the trade activity log nothing appears. I don't know if this is because of the roll over on the chart dates? Any help is appreciated
trade log snapshot.PNG / V - Attached On 2016-07-02 17:08:43 UTC - Size: 129.7 KB - 234 views |
[2016-07-02 22:22:48] |
The problem is you need to also select the particular Symbol you want to see the Trade Activity data for from the list of symbols at the top. Here are detailed instructions: https://www.sierrachart.com/index.php?page=doc/doc_TradeActivityLog.php#ViewingHistoricalTradeActivity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
