Date/Time: Sat, 11 May 2024 17:11:39 +0000
Trailing stop and fixed stop limit
View Count: 642
[2016-07-02 13:24:27] |
User171450 - Posts: 3 |
I am trading dax and minidax with demo account for now. Is there a way to implement both fixed stoploss and trailing stop? Stoploss should be 20 ticks from buy/sell price and trailing stop as optimal as it can be to keep profits running intraday or longer. Any suggestions for offsets settings and types(ticks,price,%) from you experienced users? Thanks |
[2016-07-02 22:20:42] |
Did you want the fixed stop and trailing stop to be separate orders?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-02 22:20:59
[2016-07-03 05:36:41] |
The idea is to use both if the trailing stop should fail. But I realized that that trailing stop cant go lower than ticks choosed at the beginning?
[2016-07-03 06:36:30] |
You cannot use two stops for this purpose. It does not make any sense. This is correct: But I realized that that trailing stop cant go lower than ticks choosed at the beginning?
Have a look at the different types of Order Types here: https://www.sierrachart.com/index.php?page=doc/doc_OrderTypes.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
