Date/Time: Sat, 18 May 2024 12:27:42 +0000
Previous volume study + Levels
View Count: 854
[2016-07-01 18:05:04] |
User560062 - Posts: 100 |
Hi, I come from a platform that provides a way to have average volume per bar for an average number of days. This is very useful to me. Is there a way to do this in Sierra. I have attached file to display more clearly what I am saying. Furthermore, is it possible to have price levels loaded from a csv file? |
volume.png / V - Attached On 2016-07-01 18:04:31 UTC - Size: 4.23 KB - 285 views Attachment Deleted. |
[2016-07-02 10:08:49] |
can anyone answer this please?
[2016-07-02 10:36:47] |
The general way to do this is to apply the Volume study to a Historical Daily chart and then add a Moving Average study which is Based On the Volume study. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#BasedOn Furthermore, is it possible to have price levels loaded from a csv file? https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetStudy.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-02 10:36:49] |
[2016-07-30 07:38:32] |
Adding an SMA doesn't produce the same type of data that I have requested. IRT provides this. Can you not do it?
[2016-07-30 14:17:39] |
Sawtooth - Posts: 4000 |
Have a look at the Relative Volume study.
