Date/Time: Mon, 20 May 2024 22:18:03 +0000
Sierra Chart under Wine on Linux with HiDPI
View Count: 1009
[2016-06-30 17:40:16] |
Queeq - Posts: 42 |
Hello, I understand that the setup I mentioned is pretty weird, but I'm trying to move to a new laptop with HiDPI. Linux is my obsession and I would also loathe to abandon Sierra Chart due to its obvious advantages. What I tried is setting higher DPI in winecfg. As you can see from the screenshot, not all texts comply with this change (the majority). Among those that do are "Text tool" labels, timer (top right corner) and texts within windows. Others are not. Neither do icons and graphics. Changing font size is barely an option as I have SC to synchronize settings between different computers. Others are not HiDPI. Maybe there's a simple solution that I'm missing? Thanks! Date Time Of Last Edit: 2016-06-30 17:53:26
Sierra Chart 1437 BFX.cht SC Data - All Services 2016-06-30.png / V - Attached On 2016-06-30 17:32:57 UTC - Size: 231.64 KB - 370 views |
[2016-06-30 19:11:01] |
We can only help you with giving you the documentation for changing the font size for particular text elements within Sierra Chart. If you do not know how to change the font size of a particular element, let us know which one and we will give you the relevant documentation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
