Date/Time: Tue, 21 May 2024 02:58:32 +0000
Scanning continuously Nasdaq stock
View Count: 616
[2016-06-30 01:52:18] |
Kinobe - Posts: 86 |
Hi I am wondering if it is possible with SC to scan all nasdaq stocks continuously. for instance, I would like to know the 10 first % gainer stock in realtime - ie:the scan will update at every change of the 10 first % gainer. thank you |
[2016-06-30 05:08:18] |
First, you are going to have to pay more for the data feed for this capability. Not sure what the cost would be. We would think it would be about 290 USD more a month. The functionality that might work for you is part of ACSIL and is documented here: https://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#AccessingCurrentSymbolDataForOtherSymbols See if that will meet your needs. You cannot use this functionality for something like this: https://www.sierrachart.com/index.php?page=doc/doc_StudyChartAlertsAndScanning.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-30 05:09:02
