Date/Time: Fri, 17 May 2024 19:51:20 +0000
User Email
View Count: 697
[2016-06-29 18:32:30] |
Sierra Chart - Max - Posts: 5618 |
Please take a look at the attachments, the first is from a live account, the second if from simulated live as you can see the indicator Volume Area Values is completely different, if you see he horizontal blue lines are different. The datafeed should be the same, correct? Could you please check this out and let me know/ Sierra Chart Support Date Time Of Last Edit: 2016-06-29 18:32:48
[2016-07-01 05:40:35] |
Refer to the documentation here for what needs to be done to resolve the difference: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#VolumeProfileDifferences That section is for the Volume by Price study, but also it is applicable to the Volume Value Area Lines study as well. This section here also has documentation on this subject: https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#IncorrectValues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
