Date/Time: Sun, 19 May 2024 01:42:09 +0000
ersion 1434
View Count: 527
[2016-06-28 15:11:33] |
User40526 - Posts: 166 |
I have installed version 1434 and noticed a lag in the response time (movement of mouse, etc.) that wasn't there before. I only run SC on this computer. Nothing else. I have cleared all cache. Can you make any suggestions. The lag is very disturbing.
[2016-06-28 16:32:01] |
Refer to help topic 30 for different causes and solutions: https://www.sierrachart.com/index.php?l=helpdetails30.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-28 16:32:15
[2016-06-28 17:47:47] |
OK, I had added the Market Depth Historical Graph study with the new 1434 download, so I have deleted that and hope that was the culprit.
