Date/Time: Sun, 19 May 2024 12:53:17 +0000
Horizontal price line for UK and US market open?
View Count: 1716
[2016-06-28 10:26:57] |
bootsy - Posts: 63 |
Hi there, Have been through your indicators and cannot see what appears to be relatively simple option. I would like to have an indicator that draws a horizontal bar, to the right, at a specified time, which in my particular example would be the UK open at 8am and US open at 2.30pm. I would have it on a 1 min chart so if the open is at 100.04, then a horizontal bar is automatically drawn across to the right, at this open price. Please note that it is not a bar high or low, it is simply the opening price of 1 particular bar that can be projected across a chart. Obviously these times change due to various time zone discrepancies, so the start time, and how long the horizontal bar could extend across, would have to be variable and inputted by the user. Does this indicator exist? I am aware that an indicator that shows the range within a specified time period exists. This is useful but does not display the vital opening price. At the moment I am doing it manually across various charts and it is very time consuming for a vital part of the trading day! Regards, Bootsyjam Date Time Of Last Edit: 2016-06-28 10:30:26
[2016-06-28 18:20:17] |
There is the Horizontal Line at Time study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s306 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-29 04:51:34] |
User948528 - Posts: 108 |
I use Period OHLC-Variable Period for this function.
[2016-07-05 16:52:38] |
Hi there, Am using the Horizontal Line at time study, except....it doesn't work. It's set to start at 2.30pm (14:30:00) until 5pm on the main chart, at the open price, with a solid blue line and....nothing. Have looked at all the various tick boxes and have tried turning them on and off but nothing works. How can such a simple indicator not be appearing? |
[2016-07-05 17:24:22] |
We tested the study and it does work properly. When you look at the Window >> Chart Values window do you see a value for it there? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-05 17:30:45] |
Hi there, Yes it is there, says Horizontal Line at Time (Open 08:00:00, Yes, 17:30:00) |
[2016-07-05 17:37:00] |
But what we mean is the value of the Subgraph nonzero and the open price for the day?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-05 17:37:17
[2016-07-05 18:30:44] |
Ok in chart window, underneath the line that I quoted in my previous post, it says Line 00:00:00. Which is not the time that I set it for in the settings window
[2016-07-05 18:43:15] |
Go to the chart and select Edit >> Copy Chart Values and paste the data here.
[2016-07-05 19:13:37] |
Here you go Current Quote GDAXIm 2016-07-05 20:13:05.000 Tue LastPrice: 9476.9 LastSize: 1 Daily Price Chg: -253.5 Ask: 9477.3 Bid: 9476.6 Bid Ask Avg: 9476.9 Bid Ask Diff: 7.0 Ticks Bid x Ask: 50 x 40 Daily Open: 9698.3 Daily High: 9698.3 Daily Low: 9460.4 Prev Close: 9730.4 Daily Volume: 44227 Num Trades: 44227 ******************************************* Chart Values for Last Displayed Column 2016-07-05 20:13:00.000 Bar Begin Time Region 1 GDAXIm 10 Sec #5 () Price Chg: 0.5 Open: 9477.2 High: 9477.3 Low: 9476.8 Last: 9476.9 Volume: 4 # of Trades: 4 OHLC Avg: 9477.1 HLC Avg: 9477.0 HL Avg: 9477.1 Bid Vol: 2 Ask Vol: 2 Horizontal Line at Time (Open, 08:00:00, Yes, 17:30:00) Line: 00:00:00 ******************************************* Chart Values for Tools Y: 17833 2016-07-05 19:09:30.000 Bar Begin Time Region 1 WS30 10 Sec #4 () Price Chg: 2 Open: 17810 High: 17812 Low: 17810 Last: 17812 Volume: 5 # of Trades: 5 OHLC Avg: 17811 HLC Avg: 17811 HL Avg: 17811 Bid Vol: 1 Ask Vol: 4 |
[2016-07-05 23:11:29] |
What is the Subgraphs >> Draw Style for the Horizontal Line at Time study set to? Although that should not matter. It appears as though Value Format setting for the study is not set correctly. It needs to be set to Inherited or 1. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-07-07 07:46:49] |
Hi there, Draw style: line Line style: Solid Width/size: 1 Displacement: 0 Where is this value format and how can it be set? I have now reset the study to default so it starts at 12.00. Then I set it back to 14:30:00. Guess what. The Horizontal Line at Time is now.....vertical. Please help, this is really important as I need to see the open price and don't have time to set it manually across all charts with a drag and drop line |
[2016-07-07 10:14:36] |
User41683 - Posts: 37 |
See screenshot
Value format.png / V - Attached On 2016-07-07 10:13:57 UTC - Size: 48.31 KB - 301 views |
[2016-07-07 13:12:35] |
The Horizontal Line at Time is now.....vertical. This does not really make sense with the Line Draw Style. Possibly if it is spanning only 2 chart bars, but it would never be exactly vertical. Attach a Chartbook containing only a single chart with this Study. Here are instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Let us know the time zone setting you are using in Sierra Chart. Otherwise, we cannot reproduce the problem and we are puzzled as to why there would even be a problem with this study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-08 18:07:05
