Date/Time: Sun, 19 May 2024 06:52:06 +0000
Equities historical Data
View Count: 529
[2016-06-27 21:32:09] |
User411689 - Posts: 2 |
Hi, I was wondering if I am able to get any equities data with my charting package? I'm currently using Sierra Charts through AMP Futures with the Package 3 option. |
[2016-06-27 21:33:14] |
For this you will require a direct account: https://www.sierrachart.com/index.php?page=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-27 21:49:23] |
Ahhh ok thank you for clearing that up. Is it possible to get a trial of the "full" package to test out equities functionality?
[2016-06-28 02:04:20] |
Create a new account using this link: https://www.sierrachart.com/RegisterStep1.php Let us know when that is done and we will activate it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
