Date/Time: Sat, 18 May 2024 18:26:27 +0000
User Email
View Count: 603
[2016-06-27 18:01:04] |
Sierra Chart - Max - Posts: 5618 |
One of my clients has open a simulated live and a live chart for NQ, ES and YM. In the simulated version the candles update earlier, in the live version the candles are 10-15 seconds on late,
Do you have an explanation? Thank you Sierra Chart Support Date Time Of Last Edit: 2016-06-27 18:01:21
[2016-06-28 05:52:51] |
Refer to help topic 4: https://www.sierrachart.com/index.php?l=helpdetails4.html Make sure in all instances of Sierra Chart they are using, they have Global Settings >> Data/Trade Service Settings >> Other Settings >> Timestamp Using Local Computer Clock set to False. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
