Date/Time: Sat, 18 May 2024 11:37:02 +0000
platform is freezing
View Count: 603
[2016-06-27 12:55:52] |
chris12 - Posts: 51 |
hi sc when i open my chatbook, the platform is freezing, impossible to use it i use the market depht historical graph indicator since a few days, don't know if it's linked |
Attachment Deleted. |
[2016-06-27 14:48:04] |
i reduced severals charts period with indicator "market depht historical graph, i think it's ok
[2016-06-27 17:35:38] |
One reason for the freezing is caused by the TPO Value Area Lines being used on a chart with a large number of chart bars. Reduce the Chart >> Chart Settings >> Days to Load for the chart. Refer to help topic 30: https://www.sierrachart.com/index.php?l=helpdetails30.html Also, you are using the Continuous Futures Contract chart feature and set the number of Days to Load to a very high number apparently for many of the charts. For the mini DAX, which only recently began to trade, you should not be loading more than six months of data. Not years. There is a lot of unnecessary processing going on. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
