Date/Time: Fri, 24 May 2024 06:57:06 +0000
Only little Data in Remote Chart available
View Count: 592
[2016-06-27 04:12:53] |
tobi - Posts: 351 |
I want to use a daily chart with intraday data of the Dax Future in a remote instance of SC. It seems not to be possible to show sufficient data in the remote instance. What am I doing wrong or how can this be fixed? Please see the attached screenshots for my settings.
Source-Chart.png / V - Attached On 2016-06-27 04:11:29 UTC - Size: 99.14 KB - 228 views Attachment Deleted. Remote-Chart.png / V - Attached On 2016-06-27 04:11:46 UTC - Size: 84.8 KB - 204 views Source-Data-Settings.png / V - Attached On 2016-06-27 04:11:55 UTC - Size: 47.08 KB - 232 views Remote-Data-Settings.png / V - Attached On 2016-06-27 04:12:00 UTC - Size: 37.84 KB - 219 views |
[2016-06-27 08:11:52] |
As the documentation explains you cannot use the Continuous Futures Contract feature with a remote chart data file. There is also a completely new feature to use another instance of Sierra Chart and share data from a main instance. Follow these instructions: https://www.sierrachart.com/index.php?page=doc/doc_DTCServer.php#UsingDTCServerForDataAndTradingInAnotherSCInstance This method will let you use the Continuous Futures Contract feature. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-27 19:01:39] |
tobi - Posts: 351 |
Which way would you recommend using: A: Using a new instance within the main/source SC instance? B: Installing a second instance of SC and using the DTC- Sub Instance as Data Service? Are there differences in the resources used? What/where are the differences? |
[2016-06-27 19:19:05] |
There really is no practical difference between these. It is easiest to use A.
