Date/Time: Sat, 18 May 2024 10:42:25 +0000
Tick Difference (DIT) Study
View Count: 809
[2016-06-26 21:34:02] |
Netz - Posts: 19 |
Hello. Is there a Tick Difference Study? I see it on the chart calculator. I would like to get the tick total (range) for a bar (daily or other time frames). I use Average daily Range study and Bar difference, but they show the inherited chart price difference. How do I get the tick difference as a study that I can display at a another chart region (by value)? Thanks! |
[2016-06-26 21:52:51] |
To get the tick difference, we recommend using the Study Subgraph Divide study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s281 Divide by the tick size. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
