Date/Time: Sat, 18 May 2024 18:05:23 +0000
Move chart while chart is out of visible frame
View Count: 586
[2016-06-24 13:23:07] |
Bapovs01 - Posts: 24 |
Dear support, Please check animated gif for explanation. How to move chart to the middle when changing scale.. Hope it helps. |
how to move chart.gif / V - Attached On 2016-06-24 13:21:53 UTC - Size: 443.55 KB - 229 views |
[2016-06-24 17:43:16] |
For this you need to use the Interactive Scale Move function: https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#InteractiveScalingMoveUpDown Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
