Date/Time: Sun, 19 May 2024 02:17:31 +0000
Ask Trade / Bid Trade
View Count: 1377
[2016-06-22 00:13:19] |
sampater - Posts: 243 |
Is there an ACSIL variable that indicates if the last trade is the Bid Trade or Ask Trade? I need an access by ACSIL to parameters that are in the column "Type" in the Time and Sales Window. Thanks |
[2016-06-22 05:29:18] |
Yes. This is in the time and sales data structure: http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#scGetTimeAndSales Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-22 18:32:06] |
Thank you for your answer but it is quite complicated for my purpose. I have 1 minut chart and i need the access (during receiving current market data for the symbol of the chart, or during a chart replay) only to the volume of the last trade and whether it is a Bid Trade or Ask Trade. Something simply like the sc.LastSize but indicating whether it is the volume of the bid or ask trade. |
[2016-06-22 18:43:58] |
This is definitely not complicated at all. You can easily access the last trade with the Time and Sales data. The structure member is: s_TimeAndSales::Type. It can be: SC_TS_BID, SC_TS_ASK There is no reason why anything else we should be added and it will not be added. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-24 14:50:17] |
Is s_TimeAndSales::Volume float or integer variable?
[2016-06-24 17:16:09] |
This is an integer.
