Date/Time: Sat, 18 May 2024 15:40:28 +0000
DTN IQ feed daily net change prices
View Count: 1089
[2016-06-21 23:58:13] |
User36082 - Posts: 4 |
Using DTN IQ data feed. Charts are correct but quote board daily net changes are not correct. Seems at market close daily change reflects difference between close and settlement instead possibly. Any possible fixes.
Attachment Deleted. |
[2016-06-22 01:13:34] |
Yes, this is a correct understanding: Seems at market close daily change reflects difference between close and settlement instead
Looking at the screenshot you provided, the question is whether the Settlement price and the Open price which are used in the calculations are correct from IQ Feed. That we do not know. You need to set the Quote Board to display those fields and if they are incorrect, contact IQ Feed about that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-22 01:14:13
