Date/Time: Sat, 18 May 2024 15:25:01 +0000
Study Subgraph Draw Order
View Count: 806
[2016-06-21 23:21:00] |
User948528 - Posts: 108 |
Is it possible, or could you consider adding the ability to change the order in which subgraphs within an existing study are drawn?
[2016-06-22 01:07:43] |
No this is not possible and there are no plans for this. This is quite complex.
