Date/Time: Sat, 18 May 2024 11:28:50 +0000
Different data
View Count: 591
[2016-06-21 03:56:17] |
nicktrader - Posts: 665 |
I am running SC on two computers and both should have the same setting. As you can see on the the attached files the data are different. What is the problem and how to fix it? Many thanks |
2 Computer Charts.png / V - Attached On 2016-06-21 03:53:19 UTC - Size: 202.89 KB - 267 views Settings.png / V - Attached On 2016-06-21 03:53:28 UTC - Size: 48.33 KB - 245 views |
[2016-06-21 04:52:35] |
Re-download the data in the charts with Edit >> Delete All Data and Download. Refer to help topic 43: http://www.sierrachart.com/index.php?page=doc/helpdetails43.html Also refer to: http://www.sierrachart.com/index.php?page=doc/CQGTrading.php#SolvingMarketDataFeedProblems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
