Date/Time: Sun, 05 May 2024 21:23:45 +0000
Iqfeed and IB trading quote update problem
View Count: 1383
[2013-07-15 01:15:45] |
User36492 - Posts: 48 |
I'm using 2 copies of sierra. IQFEED as data on 1. IB as the broker on 2. When I open a quoteboard or spreadsheet in copy 2 and add IQFEED symbols, the Last, bid, ask, etc. doesn't update. |
sierra.with.iqfeed.PNG / V - Attached On 2013-07-15 01:14:53 UTC - Size: 121.07 KB - 523 views sierra.with.IB.trading.and.IQFEED.data.PNG / V - Attached On 2013-07-15 01:15:07 UTC - Size: 147.59 KB - 462 views Attachment Deleted. |
[2013-07-15 19:03:48] |
This is not currently supported where you can access data from remote copies of Sierra Chart through a Quote Board. Just set up a quote board in the copy of Sierra Chart connected to IQ Feed and then detach it by selecting Settings >>Attach/Detach Window on the Quote Board menu. And then you can access it independently of the IQ Feed copy of Sierra Chart.
