Date/Time: Sat, 27 Apr 2024 22:35:13 +0000
Attached orders still doesn't work
View Count: 1321
[2013-07-14 22:53:57] |
HeavyMike - Posts: 25 |
I referred to: http://www.sierrachart.com/index.php?l=doc/doc_AttachedOrders.html However, even with the 'Attach Orders' checkbox checked, it doesn't send any attached order to my DOM in InfinityAT. In simulation it works uses the attached orders, but only within SC. |
[2013-07-14 23:00:45] |
We can only help you with Sierra Chart. Not with external programs. However, make sure that Trade >> Trade Simulation Mode On is enabled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
