Date/Time: Tue, 14 May 2024 19:55:29 +0000
Time Axis Formatting and Setting Chart Link for the DOM
View Count: 696
[2016-06-15 15:57:50] |
dBassFour - Posts: 16 |
Hello, I had a couple questions as a new user of Sierra. 1. Can I change the Time format on the chart so that it doesn't include seconds when I use a Tick Chart? 2. Can I Set Chart Link to A DOM? 3. Is there a way to change the PL to display as $'s or Ticks on the Dom? Thank you! http://www.sierrachart.com/image.php?Image=1466006241763.png Thanks in advance! |
[2016-06-15 17:18:10] |
1. No. 2. Yes of course. This is just done using the standard chart linking method: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ChartLinking In the case of the Trade DOM you need to set this through Chart >> Chart Settings >> Advanced Settings 2 >> Chart Linking. 3. Refer to the Position Profit Loss Format setting: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#ProfitLossDisplay Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-15 17:19:11
