Date/Time: Sun, 19 May 2024 06:59:07 +0000
add Symbol
View Count: 1869
[2016-06-15 09:17:26] |
User288254 - Posts: 4 |
Hello! I bought your product and have a problem with volume in the pair BTC-CNY (Okcoin). Please add normal Bitcoin Symbol BTC-CNY (Okcoin spot market) because your volume are incorrect. If it possible can you add all Bitcoin(BTC) variants from Okcoin.com and Okcoin.cn !! It's very important!Thank you!
[2016-06-16 05:16:00] |
To our knowledge all available symbols from Okcoin.com and Okcoin.cn are listed. What do you see missing? You can find the available symbols in File >> Find Symbol. For volume, make sure you use the Volume-Bitcoin study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s336 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-18 22:00:57] |
Please add BTC Futures quarterly (okcoin.com)
[2016-06-20 22:25:22] |
Support for OK Coin Futures will be added by the end of this week.
[2016-06-24 19:41:47] |
Thank you.I really need to futures.
[2016-06-28 05:38:02] |
Support for OK coin Futures will be done later today. It was more involved than expected. The symbols are already listed in File >> Find Symbol and market data will start to become available later today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-29 09:47:13] |
Well done!But now not work spot BTCCNY-OKCOIN .Last data 28.06.16 14:14
[2016-06-29 11:07:45] |
This is now fixed.
[2016-06-29 11:20:54] |
Actually we are still seeing a problem with the Chinese symbols. We need more time to resolve this.
