Date/Time: Thu, 02 May 2024 12:33:41 +0000
True and False settings in Spreadsheet, column J
View Count: 1579
[2013-07-14 01:21:58] |
User20851 - Posts: 9 |
Hi, I am trying to create a system using a spreadsheet. I have set several conditions to True in column J (such as "Signal only once per bar," and "signal only on bar close," etc.). However, whenever I save and exit the Spreadsheet, the True conditions seem to return to False. I notice that those conditions I set to True are in many cases False when I reopen the spreadsheet. How can I keep them True? Thank you. |
[2013-07-14 03:26:27] |
Sawtooth - Posts: 3990 |
Cells J57 - J70 are read only, and those T/F values are set in the spreadsheet study settings.
[2013-07-16 07:53:40] |
You need to change these values through the Study Settings window for the Spreadsheet study. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#AddingStudiestoaChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
