Date/Time: Wed, 15 May 2024 22:48:33 +0000
Less level in the DOM
View Count: 813
[2016-06-14 20:36:59] |
Laurent1 - Posts: 15 |
Hi, Is there a way to have less levels in the tradingDOM? Currently it has 25 levels on each side (with some of them being empty), I'd like the possibility to have only 10 levels. See screenshot: http://www.sierrachart.com/image.php?Image=1465936447935.png |
[2016-06-14 22:09:24] |
This can be controlled with this setting: https://www.sierrachart.com/index.php?page=doc/doc_GlobalTradeSettings.html#MaxDepthLevelsDisplayed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-15 01:18:08] |
Thanks for the answer. This is what I tried but it didn't change anything (see screenshot). Am I missing something? https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=8296 |
Attachment Deleted. chartdom.png / V - Attached On 2016-06-15 01:17:30 UTC - Size: 61.34 KB - 338 views |
[2016-06-15 02:05:55] |
We only see 5 levels of depth in that Trade DOM.
[2016-06-15 08:57:44] |
What I meant is that I'd like to reduce the number of lines in the DOM. I only have 5 levels but there are 25 lines displayed (from -3 to 20), and I'd like to have the DOM from 5 to 12.5. If I reduce the window size, everything gets compressed. |
[2016-06-15 09:41:35] |
What you want to do is reduce the price range of the scale. You need to use Interactive Scale Range for this: https://www.sierrachart.com/index.php?page=doc/doc_ScalingTheChartDOM.html#Range Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-15 10:16:50] |
Perfect thanks!
