Date/Time: Tue, 14 May 2024 00:49:28 +0000
Trade DOM request
View Count: 690
[2016-06-14 15:36:59] |
User360283 - Posts: 440 |
It would be very useful if the Trade DOM: 1. Had a CENTER button at the top so as to not have to click the display center column (I have accidentally entered a trade when I wanted to simply center the DOM (oops); 2. Display for the instrument the Daily Change, High, Low, and Volume. This would eliminate having to display the quote board, would reduce eye movement from one place to another and save some screen space real estate. Thanks |
[2016-06-14 16:49:04] |
1. You can right-click on the scale of numbers and select Reset. You can also set up a keyboard shortcut for Chart >> Reset Scales and use that keyboard shortcut. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#CustomizeKeyboardShortcuts 2. This is coming but for now use Window >> Current Quote Window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-14 17:42:23] |
doctor.scalp - Posts: 18 |
1. Keyboard Shortcut with a dedicated button on my mouse. One-click center all DOMs :) 2. Study Price overlay do the job See my screenshot I have Yesterday L/H/C/O and vwap on my DOM. Hope this help ! http://www.sierrachart.com/image.php?Image=1465925960344.png |
