Date/Time: Wed, 15 May 2024 04:54:28 +0000
adjusting drawings according to back adjust amount
View Count: 1102
[2016-06-14 06:37:43] |
Veronika Skrehotova - Posts: 8 |
Hello please could you advise me how to adjust all horizontal lines at once according to back adjust amount in the chart. I use continuous futures contract - date rule rollover, back adjusted and need to adjust all drawings. Thank you Veronika |
[2016-06-14 09:03:26] |
Yes. Refer to the documentation here for this: https://www.sierrachart.com/index.php?page=doc/doc_ChangingFuturesContract.html#AdjustingDrawingsMatchRollover Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
