Date/Time: Wed, 15 May 2024 02:26:05 +0000
Simple x tick chart
View Count: 575
[2016-06-14 00:00:35] |
User99735 - Posts: 234 |
Hi, Which of the chart type needs to be selected in chart settings to create a simple x tick chart? Regards Vivek |
[2016-06-14 01:42:50] |
You need to set: Chart >> Chart Settings >> Intraday Chart Bar Periods >> Number of Trades Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
