Date/Time: Wed, 15 May 2024 17:46:39 +0000
Problem loading Data
View Count: 584
[2016-06-13 20:25:07] |
User636679 - Posts: 32 |
New Intraday ES chart only loads one day instead of a week. I don't have this problem with any other symbol. In addition, not able to change the date range in file in the Chart settings. Thanks, Bryan |
[2016-06-13 20:55:03] |
Re-download the data in the chart with Edit >>Delete All Data Download. Unless you need to be running version 1307 for Old Spreadsheets, you should update to the latest version of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-13 20:55:59
