Date/Time: Wed, 15 May 2024 04:08:57 +0000
How to get chart to autocenter
View Count: 1399
[2016-06-13 09:15:58] |
User360283 - Posts: 440 |
Chart DOM is on. Chart DOM settings: Depth Totals, Percentages, Spread, Volume Bar all on. Chart area is 110% of DOM range. But it seems I have to manually keep moving the chart to maintain the center of the chart at the center of the DOM. How to have it Auto center? Thanks |
[2016-06-13 17:51:26] |
Follow the instructions here for this: https://www.sierrachart.com/index.php?page=doc/doc_ScalingTheChartDOM.html#AutoCenteringPriceScale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
