Date/Time: Wed, 15 May 2024 05:37:33 +0000
Main Price Graph Region
View Count: 1026
[2016-06-12 21:01:04] |
sigmadict - Posts: 95 |
Hello, 1: Is it possible to move the main price graph from Region 1 to Region 2, let's say I want to put only an Indicator in region 1, and put Main Price Graph in region 2? 2: Or I have to put the Indicator in Region 1 + have a Blank Price Chart, and Overlay Price of Main Price Graph with a Study in Region 2 ? The second alternative make it much more complicated, because we have to configure and add more Indicators, and also it makes it more complex, more problems, to fix the Axes for Price or Indicator Values. If the option 1 is not possible, would it be possible to make the configuration available ? If Sierra thinks it's valuable, it would be much appriciated. Thanks Regards Date Time Of Last Edit: 2016-06-12 21:04:39
[2016-06-13 09:12:12] |
You need to use this setting to control it: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#ChartRegion Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-14 03:27:31] |
Thanks for the reply. Any chance that Sierra put some energy on fixing this : ''When setting the main price graph to a Chart Region other than 1, Chart Trading functionality will not work properly and other chart functionality related to the main price graph may not work correctly.'' ? It would make the platform much more flexible, as to put the price between a set of indicators, up and down, following the action with layers on the top and bottom. Also, it's a pain in the ass to trade from Chart in Region 1, when what you want is a small indicator and not price, then trading functionality stop working in Region 2. I hope it inspires you to fix this problem if it's something possible. Thank you. Regards Date Time Of Last Edit: 2016-06-14 03:31:49
[2016-06-14 04:45:35] |
There is really no chance this will happen this year. We simply have no time available for this. Longer-term yes but you still could be looking at more than a year from now. Refer to the notice at the top of the support board. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-14 04:46:49
