Date/Time: Sat, 18 May 2024 06:02:31 +0000
Download Problem
View Count: 645
[2016-06-12 20:55:35] |
conr - Posts: 204 |
What's this? It won't download.
Capture.PNG / V - Attached On 2016-06-12 20:55:07 UTC - Size: 36.76 KB - 188 views |
[2016-06-12 21:57:19] |
Will be fixed in about 10 minutes.
[2016-06-12 22:12:06] |
There were a couple of problems relating to the installer. This is the reason for the problem. This is now solved. Try again following these instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate We apologize for the issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
