Date/Time: Sat, 18 May 2024 06:02:11 +0000
Old Spreadsheets
View Count: 664
[2016-06-12 11:27:10] |
User81981 - Posts: 1 |
Good morning, I've got several old spreadsheets to execute but since last update I am unable to do so. How can I update to a Sierra Chart release that allows to execute old spreadsheets ? It is not any option to update with old spreadsheets under Help menu as before. Thanks, Julio Date Time Of Last Edit: 2016-06-13 08:38:54
[2016-06-13 08:40:57] |
Download this installer to install the version with Old Spreadsheets: https://www.sierrachart.com/downloads/SierraChartSetup.exe Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
