Date/Time: Sat, 05 Sep 2026 18:02:42 +0000
Historical Market Depth - recording resolution?
View Count: 1716
| [2016-06-12 08:55:17] |
| Cavalry3162 - Posts: 523 |
Hello SC, first of all a big Thank You! I think this is a great addition to your product Now comes the questions.. in what resolution are those market depth infos recorded? is there a setting to alter that resolution (planned)? or is it the raw data (which would be awesome)? thanks, Andreas |
| [2016-06-12 09:06:06] |
There is no resolution setting. All market depth data available from a data feed is recorded. No setting is planned. This new feature is still under development. There can be some problems with it still. There should not be any problems with the underlying market depth data recording/storage but the study itself is still in development. At this point it should just be used for testing and evaluation purposes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-12 09:06:46
| [2016-06-12 10:16:21] |
i am aware that this is highly a WIP - and i appreciate that we record the raw data feed - this is awesome!
