Date/Time: Tue, 17 Nov 2026 00:04:51 +0000
Failure to connect - how do I resolve?
View Count: 1321
[2016-06-11 14:36:35]
User361147 - Posts: 5
I cannot connect to my feed - simply keeps retrying w/o success...
How do I solve this?
/M
[2016-06-11 15:18:56]
This is the log btw:
Reading Internal Order ID file. | 2016-06-11 17:16:34
Reading Trade Orders file. | 2016-06-11 17:16:34
Reading Trade Positions file. | 2016-06-11 17:16:34
Software version: 1427 | 2016-06-11 17:16:34
Uses New Spreadsheets | 2016-06-11 17:16:34
Enabled for: Advanced Features. | 2016-06-11 17:16:34
Enabled for: Sierra Chart Historical Data Service. | 2016-06-11 17:16:34
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-06-11 17:16:34
Current selected Data/Trading service: CQG FIX Trading | 2016-06-11 17:16:34
Chart Update Interval: 500 | 2016-06-11 17:16:34
Data/Trade Service Settings automatically set. | 2016-06-11 17:16:34
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2016-06-11 17:16:34
2016-06-11 17:16:42 Local computer time | 2016-06-11 17:16:34
2016-06-11 15:16:42 Local computer time in UTC | 2016-06-11 17:16:34
2016-06-11 17:16:42 Local computer time in SC Time Zone | 2016-06-11 17:16:34
2016-06-11 15:16:41 Server time in UTC | 2016-06-11 17:16:34
Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-06-11 17:16:34
Program path: C:\SierraChart\ | 2016-06-11 17:16:34
Data Files path: C:\SierraChart\Data\ | 2016-06-11 17:16:34
OS Version Number: 6.0 | 2016-06-11 17:16:34
Locale Setting: C | 2016-06-11 17:16:34
Checking for new symbol settings for cqg | 2016-06-11 17:16:34
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-06-11 17:16:34
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-06-11 17:16:34
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-06-11 17:16:34
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-06-11 17:16:43
Symbol settings are up-to-date for cqg | 2016-06-11 17:16:44
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2016-06-11 17:16:47
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-06-11 17:16:48
socket (4) | Connected. | 2016-06-11 17:16:48
CQG FIX: Sending the Logon message. | 2016-06-11 17:16:48
CQG FIX Trading | Connected to trading server. | 2016-06-11 17:16:48
CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-06-11 17:16:48
CQG WebAPI | Connecting to websocket server. | 2016-06-11 17:16:48
CQG FIX | FCM name: AMP | 2016-06-11 17:16:48
CQG WebAPI websocket (0) | Resolved address api.geo.cqg.com to IP 216.219.76.101. | 2016-06-11 17:16:49
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-06-11 17:16:49
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-06-11 17:16:49
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-06-11 17:16:49
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-06-11 17:16:49
CQG WebAPI websocket (5) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2016-06-11 17:17:10
CQG WebAPI websocket (5) | Shutdown and closed. | 2016-06-11 17:17:10
CQG WebAPI | Websocket closed. | 2016-06-11 17:17:10
CQG FIX Trading | Websocket closed. | 2016-06-11 17:17:10
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-11 17:17:10
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-11 17:17:10
CQG FIX: DisconnectFIX called. | 2016-06-11 17:17:10
CQG FIX: Sending a Logout message. | 2016-06-11 17:17:10
CQG FIX Trading | Disconnected. | 2016-06-11 17:17:10
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-11 17:17:10
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2016-06-11 17:17:10
socket (4) | Shutdown and closed. | 2016-06-11 17:17:10
CQG FIX: Disconnected. | 2016-06-11 17:17:10
File >> Disconnect selected. | 2016-06-11 17:17:12
CQG FIX Trading | Disconnected. | 2016-06-11 17:17:12
[2016-06-12 19:25:34]
This is the relevant message:
Refer to help topic 1.2:
https://www.sierrachart.com/index.php?l=doc/helpdetails1.php#h1.2
