Date/Time: Sun, 05 May 2024 09:48:42 +0000
User Email Questions - Coding - Trading Technologies and Java
View Count: 2049
[2013-07-12 22:36:23] |
Sierra Chart - Max - Posts: 5605 |
I have question to developers of Sierra.
I'm using Sierrachart with Trading Technologies. It seems that it uses TT Fix Adapter (I hope). I have separate java financial framework which I need to connect with my TT broker. What is your advice for the connection? Do you support some Sierra API for price feeds, and orders? Or connection with some your dll library - do you have example of this connection? Or use some directly way to TT Fix Adapter - do you know some java library implementation? Sierra Chart Support |
[2013-07-12 23:30:28] |
Sierra Chart fully supports the TT FIX adapter. Refer to this page for the Sierra Chart Custom Study Interface and Language: http://www.sierrachart.com/index.php?l=doc/doc_CreatingDLLs.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-07-13 06:21:46] |
User47851 - Posts: 2 |
Yes, Sierra has ACSIL language. It can be helpful. I have system written in the java, and I need the connection to sierra. I means the request for price feed, checking of orders, creation of orders. Maybe the ACSIL can be used somehow. I can use some dll-library by JPA for connection. Technically it means to have connection with execution platform api, and the price feeds. What is your advice? How to easly solve this connection? Date Time Of Last Edit: 2013-07-13 06:25:44
[2013-07-15 23:35:18] |
Please have a look at the capabilities of ACSIL to see if it meets your requirements: http://www.sierrachart.com/index.php?l=doc/doc_CreatingDLLs.html You will have access to the market data, Orders, Positions and can submit Orders. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
