Date/Time: Sat, 18 May 2024 07:25:16 +0000
User Email
View Count: 623
[2016-06-10 22:34:58] |
Sierra Chart - Max - Posts: 5618 |
We're having an issue on one machine where daily or almost daily we receive a message in SC that the computer clock is off by some large number of seconds (it isn't off, and is set to the correct time in CST). I'm not certain what the user is clicking on within SC at that point but the next day, the time is set to 1 hour in the future and we have to set it back. Is there something in SC that actually changes the computer clock such that it might end up at the wrong time for its time zone? If so, what setting should we check to try to isolate this? We can't think of any other explanation, and the user reports that they get this message about every day so I'm not sure if SC is reporting the difference or is the source of the change. Sierra Chart Support |
[2016-06-10 22:41:47] |
This is an indication that the computers TimeZone is not set correctly. Refer to: Https://www.sierrachart.com/index.php?l=helpdetails38.html Is there something in SC that actually changes the computer clock such that it might end up at the wrong time for its time zone? If so, what setting should we check to try to isolate this? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-11 00:41:19
