Date/Time: Mon, 29 Apr 2024 05:50:03 +0000
Left-side scale does not use Price Display Format setting
View Count: 2803
[2013-03-29 16:51:37] |
joshtrader - Posts: 439 |
When I set the Price Display Format to "1" for the e-mini S&P, the right-side values scale looks fine, but the left-side scale still shows the ".01" format and is not wide enough to show the entire price. http://screencast.com/t/vJ1xdW8f1 |
[2013-03-29 18:13:12] |
There is extensive documentation for this in the Chart Settings documentation that explains how this works.
[2013-03-29 18:26:13] |
Thank you for your help, I only searched for Price Display Format earlier and did not look at the left side scale documentation but should have, and it is now working as expected.
[2013-03-29 18:45:17] |
I would like to suggest the ability to more independently control the left scale. As it stands, unless there is a study with an independent, constant range, or user defined scale, the left will match the right always. I think it would be nice to allow a right scale with increments of 1, with a left-hand scale with increments of 5, for example.
[2013-03-30 20:33:32] |
This is not planned, but we are going to make sure that the width of the Left Side Scale is wide enough to show what is displayed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-03-30 20:33:52
