Date/Time: Sun, 19 May 2024 01:39:29 +0000
Make Zigzag tool stay selected after first use
View Count: 1007
[2016-06-10 10:45:58] |
phaedonk - Posts: 352 |
All tools I have used (lines, rectangles etc) stay selected after first use, so you can use them again. The zigzag tool reverts to the previously used tool. Please change that.
[2016-06-10 11:03:25] |
This will be changed in the next release.
[2016-06-21 11:44:36] |
I installed 1431, it is still the same.
[2016-06-21 11:51:32] |
This has definitely been solved. You need to press the Escape key to cancel the Zig Zag tool. Do not use another method.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-21 11:52:13
[2016-06-21 11:53:18] |
I use right click to cancel.
[2016-06-21 17:45:17] |
OK we will track that particular event down as well and solve this.
