Date/Time: Mon, 20 May 2024 20:11:48 +0000
"Extend drawing" delete my lines
View Count: 574
[2016-06-10 08:40:47] |
Ulaju - Posts: 56 |
So I click the line with the right-button, I select "extend drawing" and the line suddenly disappears instead of extending. This happened to me like 5-10 times during the last few days... kinda annoying. Anyone else experiencing this? Any easy solution? Thanks in advance ^_^ |
[2016-06-10 09:43:56] |
Are you extending the Line drawing towards the left and is this a Historical Daily bar chart? If so, we are noticing the same problem. We are looking into this.
[2016-06-10 10:38:31] |
Ulaju - Posts: 56 |
No... it happened to me on intraday standard range-bar charts mostly. Not sure towards which side... I didn't even know you can choose, I usually go for the right.
[2016-06-10 11:26:52] |
Yes we do see it happens with Intraday charts as well. There was never support for extending the first anchor point with Line drawings. This has been added. This will be out in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
