Date/Time: Wed, 15 May 2024 23:13:42 +0000
numbers bar study
View Count: 732
[2016-06-09 19:38:13] |
User780238 - Posts: 45 |
In the numbers bar study can I see If the "last" price is ether trading at the bid or ask. In other words... to always see "Highlighted" the bid / offer. I am not speaking of the diagonal reading of the volume traded. Thanks, |
[2016-06-09 19:42:25] |
opened a new 1 min chart BxA with the filter set at exclude < 200. just noticed its not matching up with time & sales. it shows zeros when time & sales might show 518 contracts for the same min. Thx
[2016-06-09 19:45:10] |
Follow the instructions here for a tick by tick data configuration: https://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-09 19:46:00] |
This is not supported: If the "last" price is ether trading at the bid or ask. In other words... to always see "Highlighted" the bid / offer. I am not speaking of the diagonal reading of the volume traded. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-14 15:20:06] |
In reply to your answer 'Follow the instructions here for a tick by tick data configuration: https://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php' the tick by tick data configuration reads " tick by tick data is Less Efficient & takes more disk space. I have no issue on disk space but I'd like clarification on what you mean by 'tick data less efficient'? Does this mean slower execution of my trades, thx |
[2016-06-14 16:52:26] |
The main problem is it will take longer to download the historical tick by tick data. You need to have a tick by tick data configuration when using the Numbers Bars study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-14 17:09:07
