Date/Time: Mon, 20 May 2024 15:42:35 +0000
Gene Sheldon
View Count: 602
[2016-06-09 17:18:41] |
User72965 - Posts: 114 |
I would like to add Price to my Tool configuration??? They are greyed out And I can't do anything with it??? How do I un-grey it so I can use price:And set it up so it will show on my drawing. I see Calculator Confif. in the manual . Labels <> It's checked. But have not figured out how to use it ... Thx Gene :) |
[2016-06-09 19:01:41] |
You can only enable the Labels >> Price when using the Chart Calculator drawing tool. Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartCalculator Here are the instructions to configure that drawing tool: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#DrawingToolConfiguration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-09 19:02:49
