Date/Time: Mon, 20 May 2024 14:53:59 +0000
Back month contracts
View Count: 534
[2016-06-09 16:37:33] |
User648008 - Posts: 12 |
I have my chart set on current contract. I need to look at June and March how can I find that symbol
[2016-06-09 17:47:50] |
You need to use the Continuous Futures Contract feature: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-09 17:48:27] |
Or refer to: https://www.sierrachart.com/index.php?l=doc/doc_HistoricalIntradayData.html#UsingExpiredFuturesContracts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-09 17:54:07
