Date/Time: Mon, 20 May 2024 12:43:27 +0000
Using GetChartBaseData to get SC_UPVOL and SC_DOWNVOL arrays from an external chart
View Count: 661
[2016-06-09 14:06:21] |
User99735 - Posts: 234 |
Hi, Am trying to get SC_UPVOL and SC_DOWNVOL arrays from an external chart, using GetChartBaseData, but the arrays returned are of 0 size. Are these two arrays supported by function GetChartBaseData? Regards Vivek |
[2016-06-09 16:54:39] |
Yes that function will return those arrays. But the chart that you are getting the data from needs to have a study which has set sc.MaintainAdditionalChartDataArrays = 1. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
